Activity Forums Adobe Premiere Pro Pro 2 SLOWS to CRAWL when timeline grows (Ripple Edit and Extract tools)
  • Pro 2 SLOWS to CRAWL when timeline grows (Ripple Edit and Extract tools)
    Posted by Melissa8 on June 29, 2006 at 1:03 am
    This is a very serious problem that I’ve had in Pro 2, as well as in Pro 1.5 — but not in Pro 1. It’s forcing me and my collaborator to all go back to Pro 1!
    If the timeline is short — say 10 minutes — then all is fine.
    But all hell breaks loose with longer timelines (say, over 30 minutes) 😡
    The Extract tool (set IN, set OUT and extract) starts taking absurd amounts of times. I’ve measured over 20 seconds!! During this time the CPU is spinning around at 100% !! Doing what?!?
    Doing a Ripple Edit operation near the end of the timeline is fine, even with longer timelines. But if that operation is performed on a clip earlier in time, it takes progressively longer — as if “weighed down” by the number of clips after it :O)
    Moving tracks with the Track Select tool has the same behavior: fine if near the timeline’s end; otherwise, painfully slow.
    Even more puzzling, the UNDO operations take the same absurdly long times as the original operations!!!
    Memory is not an issue: the “Commit Charge” in the Windows Task Manager is showing around 600 MB, and I have 1 GB.
    Any help/insight is greatly appreciated!
    Vince Becquiot replied 20 years, 2 months ago 3 Members · 4 Replies
  • Vince Becquiot
    June 29, 2006 at 5:15 pm
    I think you may have explained it in the middle of your post, CPU at 100 %;)
    But that could also be something else, what CPU(s) are you on (Speed, buffer, etc.)
    V.
  • Aanarav Sareen
    June 30, 2006 at 3:35 am
    I have seen this happen when the graphics card is on the lower side. What is the model of your grapghics card?
    Aanarav Sareen
    premiere@asvideoproductions.com
  • Melissa8
    June 30, 2006 at 11:20 pm
    Thanks for your replies.
    I’m not sure what that means…
    My computer is not top-of-the-line but, hey, we’re just talking about ripple edits and extract operations!
    I have a 2 GHz Pentium 4, with 1 GB of memory.
    The graphics card is a 64 MB NVIDIA GeForce2 MX400 AGP. I upgraded the driver when I switched to Pro from Premiere 6 a few months ago.
  • Vince Becquiot
    July 2, 2006 at 10:11 pm
    Melissa,
    Your CPU at 2GHz should be fine for simple standard def edits. A few other things to consider: Is Premiere really the only thing running at the time of the edit ?
    Antivirus can slow things down quite a bet.
    Also, if you are editing clips that already have been rendered, Premiere tends to freeze a bit on some computers. But you no longer lose most of your rendered files after that edit, as it used to be in previous versions, which I’m guessing, means quite a bet more backgroung work.
    The last things that it doesn’t deal with very well is high rez images, I mean above 2500px x…
    Vince
