Pro 13 progress box is wrong
Posted by Peter Holt on September 25, 2016 at 5:58 pmhttps://peter-ftp.co.uk/screenshots/2016-09-25_185636.jpg
The elapsed time is right, and the progress bar is probably right too; I am expecting this render to take several days.
Peter Holt replied 9 years, 11 months ago 3 Members · 5 Replies -
Steve Rhoden
September 26, 2016 at 6:10 amWhat exactly are you rendering?
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
https://www.facebook.com/FilmexCreativeMedia -
Peter Holt
September 26, 2016 at 6:56 amA 7hr movie, 1080P 50FPS, 50mbits/sec output bit rate, AVC. I am doing contrast, colour balance, NewblueFX lens correction, a bit of track motion (1.8 degrees of rotation because the camera wasn’t exactly straight) and hard-embedding subtitles (SRT import via Vegasaur, from a GPS track converted to SRT using a custom program) like you can see on this movie
https://vimeo.com/180135440On the next stage of the project I will start fresh, import the rendered file (probably about 100GB) and cut most of it out and add text titles as required.
I have seen this effect before many times and reported it on some other Vegas forum (there must be at least 5 Vegas forums :)).
I can confirm, looking at the preview footage, that the progress bar is correct (at 32% as I write) and the elapsed time is also right. The time left is now showing 1hr 21 mins 🙂
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Peter Holt
September 26, 2016 at 11:44 amAt some point this morning, since the 32% progress bar point, the time left value has jumped up
https://peter-ftp.co.uk/screenshots/2016-09-26_124322.jpg
I still think it is too small. The elapsed time has also got reset.
This is a single pass render. 2-pass ones of small movies are indicated correctly, with the progress going from 0 to 100% but showing the movie twice in the preview.
Bill Burnette
September 27, 2016 at 4:55 amCan it ever report more than 23:59:59? Anyone ever see that? If not, could be wraparound error, a la Y2K
