Activity › Forums › VEGAS Pro › Pro 10 failing to create directory
  • Pro 10 failing to create directory
    Posted by Mike Hinkel on January 3, 2011 at 11:42 pm
    I just tryed to open Vegas Pro 10 and the program fails to create a directory for the unlocked Boris BCC 7 presets. A ton of warnings. Any solutions for a quick fix?
    Jeremy Rasnic replied 15 years, 9 months ago 2 Members · 3 Replies
  • Jeremy Rasnic
    January 3, 2011 at 11:59 pm
    It sounds like a corrupt install of BCC. The best bet would be to uninstall BCC and reinstall it after restarting the system.
    If that doesn’t work try restoring your machine to an earlier state before the BCC install and then try downloading BCC7 again and installing again.
    Without error messages general help is about all that can be offered. If the error messages are too detailed, you may want to contact Borisfx about the issue you are having with the error messages in hand.
    j razz
    https://www.jrazzcreations.com
  • Mike Hinkel
    January 4, 2011 at 12:38 am
    That is what I did after thinking about it, Jeremy. The only thing I didn’t do was restart after uninstalling. All seems to be working fine now. Maybe I should go back and do it again? Thanks for your input.
  • Jeremy Rasnic
    January 4, 2011 at 2:13 am
    I think the old saying holds true… if it isn’t broke, don’t fix it 🙂
    j razz
