Activity › Forums › Apple Final Cut Pro Legacy › Printing to tape
  • Printing to tape
    Posted by Jlawry on April 21, 2006 at 12:38 am
    Running FCP 5.0.4
    Trying to print PAL – DV (not dvcam) shot on a PD150p onto tape via a Canon MV530i which i use as a deck.
    I’ve done this before fine through Premiere pro, which i haven’t used in a long time, and for some reason im not getting any video or audio being recorded onto tape. All i get is a black screen, i know the firewire is working because im telling FCP to activate the deck and start recording automatically, which it is doing.. just no picture or sound is getting through.
    I’ve gone through and checked the audio video prefs and also the external – all frames setting, and they are correct. But still im getting nothing onto this tape. I know its not the tape, its brand new, and i know its not the camera, as as much as i hated to do it, i tired doing it through my pd150 (trying to keep this in as good a shape than ever so never! use it as a deck)
    Im rather stumped.
    Shane Ross replied 20 years, 5 months ago 2 Members · 1 Reply
  • Shane Ross
    April 21, 2006 at 9:04 am
    #8 External Monitor Viewing.
    Shane’s Stock Answer #8:
    A simple path is mac > firewire > camera or deck > rca cables > tv
    Then start up your camera and tv, then open fcp.
    Then go View > External video > all frames
    Video playback should be Apple firewire NTSC (If you are using an NTSC set)
    Audio playback should be Audio follows Video
    Techinially, this should send synched video to your TV
    If for some reason you can’t view your timeline on your external monitor, there are a few things to try:
    1) Make sure that the camera/deck is connected and powered on BEFORE you open FCP.
    2) In the Final Cut Pro menu select AUDIO/VIDEO Preferences and make sure your signal is being sent out thru Firewire DV.
    3) Go to the menu and select VIEW>EXTERNAL>ALL FRAMES.
    4) Click in the % box above the image and select FIT TO WINDOW.
    5) Go to VIEW->refresh A/V devices
    6) Make sure the Log & Capture window is closed
    If you want it to play in both the canvas and the external monitor you need to go to the FINAL CUT PRO menu and select AUDIO/VIDIO settings and make sure MIRROR ON DESKTOP is selected under the PLAYBACK OUTPUT section
