Printing To DV HalfSpeed
Posted by Clay Dempsey on March 13, 2007 at 11:35 pmI am trying to print an .avi (NTSC DV) to my camera. It prints, but it is almost like it is in half speed. What am I doing wrong?
Edward Troxel replied 19 years, 6 months ago 3 Members · 10 Replies -
Clay Dempsey
March 14, 2007 at 1:53 pmI am hoping someone can give me some input here. Never had this problem before. Even when the capture is going from the machine to the recorder it is severely slowed down. It drags and I can’t figure out why.
Mike Kujbida
March 14, 2007 at 2:04 pmFirst of all, you are doing this through a firewire port I hope as USB won’t work properly.
Does it play back properly on the timeline?
If it doesn’t, make sure that you haven’t accidentally inseted a velocity envelope or altered the timeline in some way that would cause this.Check your project properties and make sure tha tthey haven’t gotten changed somehow.
My final thought is that there’s something wrong with your camcorder.
Try it with a different one and see if it works properly. If it does, then you know your camcorder is in desperate need of service 🙁 -
Clay Dempsey
March 14, 2007 at 2:09 pmEverything plays fine on the timeline, perfectly. Even when I watch the avi on my machine outside of Vegas it is fine. Maybe it is the camera. Realizing I’m about to loose a contract is not a good feeling.
Edward Troxel
March 14, 2007 at 2:17 pm -
Clay Dempsey
March 14, 2007 at 2:30 pmThat’s the thing, the camera is not picking up like a drive. I was thinking I would just be able to drag and drop the project into the camera. Didn’t work like that. Are there more ways to save this to tape. Just a quesion, DV NTSC should work correct?
Edward Troxel
March 14, 2007 at 2:39 pm -
Clay Dempsey
March 14, 2007 at 2:52 pmYes, hooking up with Firewire. Going to Tools>Print To Tape. I’m not sure of the model number, but the camera is a Sony Mini DV. Figured it would work easily.
Edward Troxel
March 14, 2007 at 4:34 pm -
Clay Dempsey
March 14, 2007 at 4:57 pmcan you go into a little more detail about this process? i’m a little confused on how this works since i can’t really get it to the camera to start with. this is what i did:
1: opened dvd in vegas 7
2: edited out everything i need
3: rendered as DV-NTSClike i said, i also rendered as .wmv and .mov, both play fine on the pc.
Edward Troxel
March 14, 2007 at 6:00 pm
