Activity Forums Adobe Photoshop Printing multiple contact sheets
  • Printing multiple contact sheets
    Posted by Jagaul on June 14, 2005 at 2:08 am
    I am attempting to print one each of 44 contact sheets which were created from a folder of wedding jpg files. For some reason I am only able to print one of the 44 at a time, then need again click print and go through the entire print setup again.
    Any help would be greatly appreciated as I just don’t have the time to set here through prining of all 44 one at a time.
    Is it possible to batch this in some way.
    Thank you in advance.
    Judy
    Richard Harrington replied 21 years, 2 months ago 2 Members · 1 Reply
  • Richard Harrington
    June 14, 2005 at 3:20 am
    Use Acrobat to merge them all into one pdf
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro On The Spot & After Effects on the Spot
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.vasst.com
    edit – produce – direct –
