Activity › Forums › Adobe Illustrator › Printing in the bottom left of a document in illustrator
  • Printing in the bottom left of a document in illustrator
    Posted by Scott Davies on December 22, 2016 at 10:39 am
    Hi everyone,
    Just found this forum so hello!
    I have a question about print settings in Illustrator.
    In Corel Draw you can set your print job to print in the bottom left corner (or right or centre or whatever) and I want to be able to do this in illustrator. Is it possible?
    This is a requirement for our vinyl cut printers you see. Hense the odd request.
    Scott
    Vincent Rosati replied 9 years, 9 months ago 2 Members · 3 Replies
  • Vincent Rosati
    December 22, 2016 at 2:14 pm
    I’m not sure I understand.
    My initial thoughts are:
    1) If you want your art to print on a certain portion of a piece of paper, you would set the document to use an artboard at the appropriate size, then position the art accordingly.
    2) You can set the center of an artboard by enabling Rulers, then drag the Ruler corner (where the 2 rulers meet), to any point on the artboard, to set the center.
    I’m not sure either of these options address your issue. Let us know.
    Vince
    *Please remember to Like an answer if it solves your question or gives you a good idea.
  • Scott Davies
    December 23, 2016 at 11:08 am
    Hi Vincent,
    Thanks for taking the time to reply, but unfortunately it doesn’t resolve my problem ☹
    I’m using a Roland BN-20 printer, which used a large roll of vinyl and a cutter to cut out letters (and simple one colour artwork) which is then weeded and pressed onto a t-shirt.
    Unfortunately, without having an option to print specifically in the bottom left/bottom right of the document, it doesn’t print correctly/wastes vinyl. ☹
    Scott
  • Vincent Rosati
    December 23, 2016 at 3:15 pm
    Hmmm. When I worked in a sign shop, I remember that the vinyl guy often talked about nesting and saving material, Editing the artwork, or duplicating the art, so it uses the whole roll width.
    Another thing that might be an option. Adding some sort of registration mark to the artwork…
    If your art is 3″, and your roll is 12 inches, you could add a small X symbol that’s about 9 inches off to the side art, making your vector the same width of the vinyl.
    Just a thought.
    Vince
