Activity › Forums › Adobe InDesign › Printing Bigger than the paper
  • Printing Bigger than the paper
    Posted by Reuben Zuazua on August 8, 2009 at 4:29 am
    Try and explain
    I own an Epson R2400 with 13×19 Sheets of Paper.
    How can I setup to print a document that is 36×48.
    I thought To build my project that size and hit print and it will just use the amount of pages it needs and i would have to piece the pages together. but i was wrong.
    So What is the proper setup to print a document that is 36x48in using as many 13×19 paper to print it up.
    Reuben Zuazua
    After Hours Production
    graFX Artist
    indie@afterhoursproduction.com
    Louise Robinson replied 17 years ago 3 Members · 4 Replies
  • Terry Mikkelsen
    August 8, 2009 at 1:02 pm
    Yes, you were right. Design at 36×48. When click print, choose the “setup” tab on the left and then click on “Tile” at the bottom right. Make sure you have the paper size set to 13×19. It will print guides to help you line up the sheets and then you paste together.
    Tech-T Productions
    http://www.technical-t.com
  • Reuben Zuazua
    August 8, 2009 at 2:37 pm
    Thank you, i will give this a shot
    Reuben Zuazua
    graFX Artist
  • Reuben Zuazua
    August 20, 2009 at 6:36 pm
    Did not work… Im printing with Preview and page 1 looks good, page 2 and 3 look like abstract art, then page 5 is ok, 6-7 then 8.. blah…
    Its a PDF of a Cities map.. Kinko will not in large it.. I just want to be able to learn the area streets and back roads…. it will help me arrive faster (EMT/Firefighter).. oh well
    thank you,
    Reuben Zuazua
    graFX Artist
  • Louise Robinson
    September 7, 2009 at 8:24 am
    Can you set size paper up as a custom size then tick scale to fit media when printing??? Lx
