Activity Forums Apple Final Cut Pro Legacy Print to Video problems
  • Print to Video problems
    Posted by Sean Simms on July 4, 2011 at 12:06 am
    My timeline for one project will not allow me to print to video (mini dv) on any computer….and when I try to view it on the tv monitor it doesn’t play normally….it only shows the first frame I start on and then the new frame that I stop on….in between I just get the first frame….everything else about the project is normal (it plays in the viewer and canvas just fine) and I only started having this problem yesterday…I have tried two different computer so I am sure that this is related to the file…..also when i print to video I do get audio but no video….
    FCP 6
    Sean Simms replied 15 years, 2 months ago 2 Members · 4 Replies
  • Jerry Hofmann
    July 4, 2011 at 12:31 am
    What are your sequence settings, and what were the properites of the source clips? Were they the same? All DV?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Sean Simms
    July 4, 2011 at 12:42 am
    oddly my clips are all dvcpro 23.97 but the the sequence settings all say dvcpro 60….I tried changing them but no luck…..unless i’m doing it wrong…..also i didn’t have this problem when i began the project so i don’t know why it would come up now……my settings haven’t changed at all….
  • Jerry Hofmann
    July 4, 2011 at 12:54 am
    Just for kicks, create a new sequence. Put a clip from the browser in it and say yes when it asks to conform to the clip’s properties. Post then what the sequence settings become.
    Jerry
    Current DVD:
  • Sean Simms
    July 4, 2011 at 12:59 am
    Sounds good…i actually thought my back up plan would be to open up one of the sequences from the autosave vault from before this happened and copy and paste my current sequence into it….
    but I’m gone from the editing studio until July 5th…..so we’ll see what happens then…..
