Activity Forums Apple Final Cut Pro Legacy Print To Video from Final Cut Pro 6 to Firestore FS-4
  • Print To Video from Final Cut Pro 6 to Firestore FS-4
    Posted by Pj “the pelican” on August 9, 2007 at 9:34 pm
    Trying to export a video from Final Cut Pro 6 to our Firestore FS-4 via a firewire. The firestore will not start recording. This process works just fine with our Avid system. Anyone else running into this type of problem?
    Stace Carter replied 19 years ago 2 Members · 1 Reply
  • Stace Carter
    August 14, 2007 at 1:59 pm
    PJ,
    I’ve not tried this from an NLE but have rolled plenty of footage from our SP Deck to the firestore – I would suspect you could simply play from the timeline and manually hit record from the front of the FS? Might need to check to make sure you’re monitoring via firewire.
