Activity › Forums › Apple Final Cut Pro Legacy › print to video 16:9 to 4:3 Pal project
Posted by Prickimage on July 23, 2007 at 11:38 pmI’m wanting to ‘print to video’ a 1024×576 Pal project to SD camera
A 4:3 letterbox would be ideal
How do I do this?
Prickimage replied 19 years, 1 month ago 2 Members · 4 Replies -
Todd Gillespie
July 24, 2007 at 6:17 pmCreate a new 4×3 sequence and ‘nest’ your 16×9 sequence into the timeline. It should automatically give you a letterbox of the sequence. If not reduce the size down until all the video fits onto the screen (around 75%).
Lay to tape.
Good Luck,
Todd at UCSB
Television Production -
Prickimage
July 24, 2007 at 8:21 pmThanks for that Todd! Definately sounds do-able.
Is there a way without losing quality? Anamorphic?
I tried to print as anamorphic but must have settings wrong…
Cheers
Todd Gillespie
July 24, 2007 at 9:21 pmHi,
not sure what you’re trying to do?
You can lay to tape as an anamorphic 16×9, but you will need to view the tape on a display that will show you 16×9.when you nest the sequence in a 4×3 timeline, you’re going to create a letterbox program, that will correct on any display.
Neither way will loss any quality.
Good Luck,
Todd at UCSB
Prickimage
July 24, 2007 at 9:27 pmOk cool…Thanks Todd again
Great to know I have 2 options
I’m trying to archive my projects to free up space on hard drive
Cheers
Shaun
