Activity Forums AJA Video Systems Print to Tape Problem
  • Print to Tape Problem
    Posted by Jeff Coffman on March 28, 2006 at 8:16 pm
    Hello
    I’m trying to Print to Tape using the Kona 2 Capture Card going into a Digibeta Deck. The Sequence and media is 10-Bit UnCompressed 720 X 480. The video seems to be getting pixelated in some parts once I play the tape back.
    I think a possible reason could be that the closest option for playback that I’m offered through the Kona 2 is 720 X 486. If this is the case does anybody know how I can change that setting.
    Thanks so much.
    Jeff
    Jeff Coffman replied 20 years, 6 months ago 1 Member · 1 Reply
  • Jeff Coffman
    March 28, 2006 at 8:36 pm
    I am trying to Re-Render the sequence after changing the sequence frame size to 720 X 486, but I don’t know if that is the problem..
    Jeff
