Activity › Forums › Apple Final Cut Pro Legacy › PRINT TO TAPE-24fps timeline issues
  • not quite understanding that instruction as it has always been set to firewire ntsc 720×480, what was it supposed to be set to before?
  • Jeremy Garchow
    July 31, 2007 at 8:11 pm
    I don’t know what to tell you except that something is messed up. Perhaps it’s a setting on your camera that isn’t allowing firewire in.
    Jeremy
  • well thanks for the advice,
    Im still not quite sure what you meant by changing my video output to 29.97 and the view menu instructions View-Video Playback-dv 29.97 I am hoping to try this. Also If the firewire was messed up im not sure why I would be able to see the video frame by frame when changing the view-external-current frame. And also I do get a clear audio signal. I think it has to be a setting somewhere I just have to find the right combination…
    Danny
  • Jeremy Garchow
    July 31, 2007 at 10:13 pm
    THat should do it. Can you play regular dv footage out?
  • Jason Lyons
    August 1, 2007 at 7:37 am
    SD NTSC = 29.97
    If you have been editing in 23.98 SD and you are trying to output to DV SD over firewire then I think you are trying to fit a square peg in a round hole. Thats why a software conversion like you are trying sounds logical. And following Shanes #8… and if you still dont have video and audio then RESTART the mac.
    Your LCD is not confined by NTSC SD 29.97 frame rate that TV’s are- thats why you can hear but not see through NTSC output.
    Seems like you should be getting video and audio through firewire if you have dropped your seq into a DV-NTSC 29.97
    Best wishes
    j
  • Jeremy Garchow
    August 1, 2007 at 3:07 pm
    [avidzombie] “If you have been editing in 23.98 SD and you are trying to output to DV SD over firewire then I think you are trying to fit a square peg in a round hole.”
    Since FCP 3, Final Cut has been able to add pulldown to dv 23.98 video over firewire. This is not a mystery.
    Obviously, he has some settings wrong.
    Jeremy
  • I was able to remedy the problem just a little late for yesterdays mailing but oh well such is life…
    it was an aspect ratio issue. The footage was captured and edited at 720×486 I just placed the sequence in a 720×480 timeline and it worked. Thanks everybody for all of the suggestions
    Danny
  • Jeremy Garchow
    August 1, 2007 at 4:14 pm
    If you had made to true dv sequence by selecting the 23.98 easy setup, then creating a new sequence and nesting, you would have had a dv sequence.
    Jeremy
Page 3 of 3
