Activity › Forums › Apple Final Cut Pro Legacy › PRINT TO TAPE-24fps timeline issues
  • no change,
    I have the 10b timeline nested in a 23.98 timeline rendered. easy setup is for dv-ntsc 23.98 I can record the audio but I get no video in the LED… Any Ideas?
  • Shane Ross
    July 31, 2007 at 7:13 pm
    #8 External Monitor Viewing.
    Shane’s Stock Answer #8:
    A simple path is mac > firewire > camera or deck > rca cables > tv
    Then start up your camera and tv, then open fcp.
    Then go View > External video > all frames
    Video playback should be Apple firewire NTSC (If you are using an NTSC set)
    Audio playback should be Audio follows Video
    Techinially, this should send synched video to your TV
    If for some reason you can’t view your timeline on your external monitor, there are a few things to try:
    1) Make sure that the camera/deck is connected and powered on BEFORE you open FCP.
    2) In the Final Cut Pro menu select AUDIO/VIDEO Preferences and make sure your signal is being sent out thru Firewire DV.
    3) Go to the menu and select VIEW>EXTERNAL>ALL FRAMES.
    4) Click in the % box above the image and select FIT TO WINDOW.
    5) Go to VIEW->refresh A/V devices
    6) Make sure the Log & Capture window is closed
    If you want it to play in both the canvas and the external monitor you need to go to the FINAL CUT PRO menu and select AUDIO/VIDIO settings and make sure MIRROR ON DESKTOP is selected under the PLAYBACK OUTPUT section
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Jeremy Garchow
    July 31, 2007 at 7:33 pm
    What LED are you talking about? Some sort of LED light projector?
  • I was talking about the LED screen on the camera. Anyway nesting the timeline didn’t work. Do you have any other ideas. should I be looking at the hardware? I just captured footage from the camera yesterday so I know the connection was working well less than 24 hours ago and I do get an audio signal, just no video
  • Jeremy Garchow
    July 31, 2007 at 7:40 pm
    I get it, I think you mean LCD of the camera.
    Change the video output to 29.97 firewire.
    View > Video Playback > dv 29.97
  • Shane Ross
    July 31, 2007 at 7:41 pm
    Did you try ANY of my suggestions?
    And are you on a DV 29.97 sequence? Or 23.98 now?
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • thanks for the suggestions but none of them led to any progress…
  • yeah sorry, LCD… Okay will try the switching to 29.97. I did try this earlier though and it lead to issues in terms of the edit.
    will let you know
    Danny
  • I don’t have an option for dv-29.97 under view-videoplayback-the only applicable option is apple firewire ntsc (720-480) I don’t see any framerate options, is there something I am not seeing?
    also when you say change video output to 29.97 were you refereing to the playback? or do I go back into easy setup and change it again to regular dv-ntsc on top of the playback change?
    thanks
    Danny
  • Jeremy Garchow
    July 31, 2007 at 7:55 pm
    Just use the view menu and change it to firewire 720×480.
Page 2 of 3
