Activity Forums Adobe After Effects Primatte Keyer problem in AE CS6
  • Primatte Keyer problem in AE CS6
    Posted by Tom Small on June 2, 2013 at 6:23 pm
    It’s happened over and over again. It first started when I would move a layer in my timeline, and all of a sudden my greenscreen layer turned purple. So I apple+z’d it and got my key back. Then I would reorder effects on the GS layer and lost my key again. Hit Undo and it was back. What a pain.
    Now I go to export a test and it turns purple the minute I hit render!! I cancelled the export and go back into my comp and the rug is purple again. PLEASE HELP!!! DEADLINE MONDAY AND I’M STARTING TO GET FREAKED OUT!
    Tom
    Tom Small replied 13 years, 3 months ago 2 Members · 4 Replies
  • Tudor “ted” jelescu
    June 2, 2013 at 7:38 pm
    Do you get the same result with Keylight?
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Tom Small
    June 2, 2013 at 7:53 pm
    Thanks for the response man. Keylight doesn’t glitch like this, but I’m getting a much better key out of primatte in this instance and would just like it to work right.
    I’m getting it to work occasionally, it’s just a PITA. I have to redo the key every now and then and most of the time it’s staying. It’s odd to me, because normally I can search the web and find others having the same issue when I have a problem, but not in this instance. I posted on redgiants forum hopefully they’ll take a look at it.
    Thanks again.
    Tom
    June 2, 2013 at 9:53 pm
    It’s a weird issue- never heard of something like that. If you find an answer post it here so others can benefit from it.
    In the mean time here are a couple of pointers for Keylight:
    Use the Intermediate result for less noise
    Apply a Matte Choker to refine edge
    Use AE’s own spill suppressor
    This usually does the trick for me.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Tom Small
    June 2, 2013 at 10:39 pm
    Thanks for the tips- I’ll try out AE’s spill suppressor… I’ve gotten pretty good at many settings in key light but I’ll try it with just the one’s you suggested and see how that works. I love primatte’s Auto compute, it’s pretty spot on sometimes…
    I’ll be sure to post if I figure out the problem.
    Tom
