Activity Forums Maxon Cinema 4D Primative circle, # of points?
  • Primative circle, # of points?
    Posted by Tom on July 26, 2007 at 10:42 pm
    Is there a way to increase the number of points on a primative circle before or after you make it editable?
    I want to start with at circle and build a complex shell before lofting.
    IT seems that there are only 4 points on a privative with no way to adjust it?
    TH
    Samir Kharchi replied 19 years, 2 months ago 2 Members · 1 Reply
  • Samir Kharchi
    July 26, 2007 at 11:30 pm
    Well, you can always simply select all points (after conversion, because as a primitive it uses virtual intermediate points to get a smooth representation), right mouse click and use the command “subdivide” to add more points.
    Samir
