Activity Forums AJA Video Systems price difference between Kona LH and Kona 3X?
  • price difference between Kona LH and Kona 3X?
    Posted by Paul Nevison on March 2, 2007 at 1:46 pm
    are the prices for the Kona 3X out yet? what is the price difference between the two cards considering the extra functionality you get from the 3X card?
    G5 DP 2.0 (Power PC)
    4.0G RAM
    OS 10.4.8
    QT 7.1.3
    FCP 5.1.2
    BMD Decklink Extreme 5.9
    PAL Land
    Aja Sales department replied 19 years, 6 months ago 5 Members · 6 Replies
  • Bob Zelin
    March 2, 2007 at 2:45 pm
    If the price difference is even as much as $1000 – if you have to upconvert from SD to HD, the price is unimportant. If you have no money, and do a lot of Beta and composite video work, the converters to change Beta to SD would cost more than $1000 – so you are better off sticking with the Kona LH.
    If you are working in HD (not HDV), this means that you have big money projects, and can afford a HD VTR and a HD monitor. At this point, the price of the card becomes unimportant, and so you can afford the extra money for the Kona 3X. However, if you have no money, you probably can’t afford an HD VTR (other than HDV or P2), and so you should stick with the Kona LH, which is more suited for analog products, anyway.
    Bob Zelin
  • Walter Biscardi
    March 2, 2007 at 2:51 pm
    [Bob Zelin] “If you are working in HD (not HDV), this means that you have big money projects, and can afford a HD VTR and a HD monitor.”
    Really? I want some of those big money HD projects. Haven’t seen any of those come through here yet. Feel free to tell those big money projects they’re welcome to use our shop!
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Bob Zelin
    March 2, 2007 at 4:55 pm
    listen Mr. Smartie Pants – there is a big difference working with material that came from a crew that shot with a Varicam, and you are editing with a Panasonic AJ-HD1200A or AJ-HD1400 (or HD Cam) – and a crew that shot with a Sony Z1U or Panasonic HVX200, and is using an HDV VTR (like the 10 or the 25) to edit with.
    If these two workflows are the same budget – then YOU are doing something wrong with your business model.
    bob Zelin
  • Mark Maness
    March 2, 2007 at 4:57 pm
    If you get too much work… I’ll take them off your hands, Walter!
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Aja Sales department
    March 2, 2007 at 5:21 pm
    The KONA 3X is the same price as the KONA 3, with a US MSRP of $2990, and it is shipping now. It also uses the same optional K3-BOX breakout box.
    Thank you,
    AJA Video Systems
    +1 (530) 274-2048 Intl.
    (800) 251-4224 US
    sales@aja.com
    March 2, 2007 at 5:31 pm
    I also should have mentioned the differences. KONA 3X/3 includes features not found on the KONA LH, such as:
    – 10-bit hardware-based SD-to-HD Up-conversion.
    – 10-bit hardware-based HD-to-HD Cross-conversion.
    – 16-channel embedded audio.
    – 8-channel AES audio (2-channel on the LH/LHe).
    – Dual-link SDI support, including 4:4:4.
    – 2K support, via HSDL in/out, and realtime (positionable cropped) playout of 2K to 1080psf and (downconverted) SD video.
    …the KONA LH/LHe, on the other hand, offers analog SD/HD inputs that are not found on the KONA 3X/3.
    Please feel free to contact us if you have additional questions.
    Thank you,
    AJA Video Systems
    (800) 251-4224 US
    sales@aja.com
