Activity Forums Square Box CatDV Previously Saved Log
  • Previously Saved Log
    Posted by Steve Leary on January 4, 2012 at 9:48 pm
    I inadvertently deleted a field of information from a pick list I made on an entire catalog. Is there a way to go back in time to look at a previously saved log and re-save it as new – like you can do with a project in Final Cut Pro?
    Matthew Stamos replied 14 years, 8 months ago 4 Members · 3 Replies
  • Rolf Howarth
    January 5, 2012 at 2:00 pm
    If you’re working standalone and save catalogs to a .cdv catalog file then CatDV will normally save the previould catalog as a .old file. If you’re using the CatDV Server however then it doesn’t keep old versions I’m afraid as this would quickly use up a lot of space. (Deleted clips are moved to the recycle bin however, and deleted after two weeks.)
  • Bryson Jones
    January 5, 2012 at 6:20 pm
    Not that it helps you if you don’t have one, but here’s a post about setting up a backup job.
    If you guys out there aren’t getting at least a nightly, please set it up now.
    https://forums.creativecow.net/readpost/278/875
    bryson
    bryson “at” hidefcowboy.com
    hidefcowboy.com
  • Matthew Stamos
    January 10, 2012 at 4:28 pm
    This database backup post should be a sticky!
