Activity Forums Apple Final Cut Pro Legacy Previewing tapeless material while batching XDCam
  • Previewing tapeless material while batching XDCam
    Posted by Karim Daire on November 10, 2009 at 10:43 am
    I am working quick+dirty on a Macbook Pro with XDCam Material… I preview through a HD Monitor connected via DVI which is enough for my needs. Anyway, its annoying that if you preview your XDCam Material with the Sony Transfer there is no large preview available you can send to an external viewer or monitor.
    Which workflow is best for this or do I need a Video Card from AJA/Matrox for this…. do they support the Sony plugins??
    Karim
    -Karim-
    Andy Mees replied 16 years, 10 months ago 2 Members · 1 Reply
  • Andy Mees
    November 10, 2009 at 12:19 pm
    Thats correct. The XDCAM Transfer app downloads and thereafter lets you view the low res proxies so as to make your logging decisions, those proxies are not really of high enough resolution to support large screen playback.
    The workflow is to view the proxies, mark/log the clips needed and import … the process is sequential: view a clip, mark/log areas for ingest, press import, view the next clip, mark/log areas for ingest, press import, view the next clip, … etc. By the time you have finished logging then most of your media will already have imported in the background and you can begin your edit; the remaining clips will continue to import whilst you edit.
    Best
    Andy
