Activity Forums Adobe After Effects Preview stuck on play when using comp panel in second monitor
  • Preview stuck on play when using comp panel in second monitor
    Posted by Francesco Benciolini on May 20, 2020 at 9:30 am
    Hi, i’m encountering a strange problem: if i have the composition panel in a second screen and i playback a preview; everything is fine on 100% or 50% screen dimension.
    But if i click fit to screen and get an odd percentage (like 83%), or if i set it to a non round precentage, the playback works for a second then it stutters and the program locks himself, i can’t stop the playback until it reaches the end.
    The problem presents itself even when i have all the comp cached.
    these are my specs:
    Laptop
    CPU: i7-9750
    GPU: RTX2060
    RAM: 32gb (28 reserved for adobe)
    I tried clearing the cache but i still have this issue.
    Anyone else has seen this problem?
    Post Production Supervisor
    Kondoo Video
    Milan, Italy
    Francesco Benciolini replied 6 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
