Activity Forums Apple Final Cut Pro Legacy Preview settings
  • Colin Mcquillan
    April 3, 2011 at 6:28 pm
    Preview as in your external monitor?
    Final Cut Pro drop down menu –> System Settings –> Change frame offset value to ‘0’ (default is 4)
    Also, If you are playing through un-rendered elements on a timeline this can also cause the external monitor’s picture to lag behind what is playing in the canvas.
    Colin McQuillan
    Vancouver, B.C.
    “Live, love, laugh and be happy.”
  • Kristoffer Gimle ruud
    April 3, 2011 at 6:32 pm
    Thanks man!
    Does this effect the final result i any way?
    April 3, 2011 at 6:35 pm
    Thanks man, but it didn’t work.. I guess my macbook is too slow for 1080p footage then?
  • Colin Mcquillan
    April 3, 2011 at 7:02 pm
    Depends on where you have the footage stored and the format of your HD Footage.
    If you have the footage on the internal drive of your laptop.. then you’re gonna have trouble.
    If your footage is on a FW400 or USB drive, you’re gonna have trouble.
    If you footage is uncompressed you’re gonna have trouble.
    If you have your footage on a FW800 drive, but the drive is almost full, you’re gonna have trouble.
    Colin McQuillan
    Vancouver, B.C.
  • Colin Mcquillan
    April 3, 2011 at 7:03 pm
    No, this wont affect the final result
    Colin McQuillan
    Vancouver, B.C.
  • Colin Mcquillan
    April 3, 2011 at 7:13 pm
    What format is the footage, and where do you have it stored?
    If you primarily work with HD footage on a macbook pro I would recommend to work in ProRes 422, get an express34 e-Sata card and a fast drive like the G-RAID (as long as you have a MBP with the express slot, if not then go with FW800 drives – the G-RAID has this connection as well)
    Colin McQuillan
    Vancouver, B.C.
    April 4, 2011 at 5:28 am
    That sounds like the right problem. I’ll try compressing the files and then see what happens! Thanks again!
