Activity Forums Adobe After Effects Preview renders entire comp – not just work area.
  • Kazumi Hatori
    July 22, 2012 at 10:21 am
    I countered this problem too and can’t find help…
    Not a single button on the keyboard can stop the progress,
    in that case, I can only force quit my after effects….
  • Gabriel Baryard
    July 22, 2012 at 7:15 pm
    So far I haven’t found a fix for this, but if I do I’ll let you know. At this point it this problem occurs indiscriminately. Sometimes it will do it and sometimes it behaves as it should.
  • Kazumi Hatori
    September 9, 2012 at 2:00 pm
    I found a symptom for the problem projects:
    I used a lot of warp stabilizer.
    Known issue?
