Activity Forums Apple Final Cut Pro Legacy Preview Problems
  • Preview Problems
    Posted by Sachin Desai on March 7, 2009 at 10:21 am
    HI!
    When I edit my videos on time line and use some transitions lets say a crossfade for instance. now my problem is it runs smooth and everything but when i change the duration or may be shift the transition little reverse or forward the old transition preview remains.. meaning a black frame will appear and shot will start as if dip from black and than again my original transition..
    This goes in the final export also…
    what could be the reason… or I should remove the temp scratch for previews…
    thanks
    Rafael Amador replied 17 years, 6 months ago 2 Members · 1 Reply
  • Rafael Amador
    March 7, 2009 at 1:31 pm
    [Sachin Desai] “what could be the reason… or I should remove the temp scratch for previews.”
    What means “The temp scratch for previews”?
    Try deleting the “Constant Frames” . In the Renders folder.
    Rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
