Activity › Forums › Apple Final Cut Pro Legacy › Preview enabler in FCP
  • Matthew Brunn
    March 27, 2006 at 9:58 pm
    Do you have deck control? What is your hardware configuration?
    Hope this helps-
    Matthew
    Quad 2.5 G5
    OSX 10.4.X
    Ram 4GB
    FCP 4.5/AE 6.5/DVDSP3
  • Kevin Monahan
    April 1, 2006 at 1:46 am
    Often you must trash your preference files when this happens.
    Go to kenstone.net for the article on that.
    The more important thing to understand is WHY that is happening.
    Likely you are using FireWire drives and perhaps even daisy chaining your DV Cam or deck to the drive. This is not an ideal way to be set up – as the FireWire bus is becoming too crowded to display the image on both your video monitor AND the Log and Capture Window.
    Of course, if you don’t have a video monitor, you’ll never realize this, so hook one up – or at least a TV set. You hook it up through your deck or camcorder.
    To prevent this from happening again and you feel you MUST use unsupported FireWire drives, get a PCI card with extra FireWire ports on them and place that inside your G4 or G5. If you have a PowerBook then you’ll need a Card Bus adapter with FireWire ports on them.
    If you are running an iMac or iBook, then you are SOL as far as fixing the problem.
    Hope this helps you.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
