Activity › Forums › Apple Final Cut Pro Legacy › Preview disabled
  • Preview disabled
    Posted by Kim Mckay on October 21, 2008 at 10:02 pm
    I have read the many posts on this subject, but none with my problem…
    here are my specs:
    Final Cut 5.0.4
    Mac OSX 10.4.11
    Sony HVR-M15U deck
    DV NTSC 48 khz
    Firewire NTSC
    Digital Cinema desktop preview
    I have used the DV cam tapes and no problem capturing. However the mini dv tape does not work.
    I can hear audio, but I see color bars and preview disabled. Same thing on imovieHD.
    I have restarted, unplugged the deck, still doesn’t work…
    any suggestions?
    thanks 🙂
    Kim Mckay replied 17 years, 11 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    October 22, 2008 at 12:57 am
    You need to turn that deck so the 1394 mode or the ilink mode or whatever it’s called on there is in DV mode and not HDV mode. Sorry, I don’t have the exact menu as I haven’t used that deck before, but I’d bet that it will solve your problem.
    Jeremy
  • Kim Mckay
    October 22, 2008 at 2:02 am
    I did that as well, in the HDV/DV sub menu it was on auto, and I changed it to DV…still only audio, and no video….
  • Kim Mckay
    October 22, 2008 at 2:08 am
    It worked! I changed it to DV on the in/out rec AND the i.link set section….THANKYOU 🙂
