Activity Forums Adobe After Effects Prevent mask from bleeding through
  • Prevent mask from bleeding through
    Posted by Bart Van zon on April 24, 2009 at 2:11 pm
    i want to show a movie inside a text,
    i thought the best way to do so is by turning the text into a mask, and masking the movie with the text, setting the mask to add and voila a movie in a textshape… however the mask is bleeding through, which could be fixed with a bit of blur i guess but i was wondering if there’s a way to make the mask cut the clip at exactly the mask borders, so no bleeding through at all.. making the movie the exact same size as the text.
    i can imagine this all sounds a bit confusing so i’ve added an image of what i mean by bleeding through, top part showing the mask lines and the movie going a couple pixels through it, and bottom part showing that these few pixels are quite a big deal because it makes the text look awfull
    Bart Van zon replied 17 years, 4 months ago 27,946 Members · 1 Reply
  • Bart Van zon
    April 27, 2009 at 7:12 am
    a lot easier and a lot sharper 🙂
    thanks for the fast answer!
    bart
