Activity Forums Apple Final Cut Pro Legacy prevent clip shifting on delete
  • prevent clip shifting on delete
    Posted by Cade Muhlig on July 24, 2007 at 7:42 pm
    say i put a clip somewhere in the middle of my timeline, and i decide later that i want to take it out again, i would usually just click it and hit delete. but when i do that, the clips to the right shift down left, and messes things up.
    i know a work around (moving the clip to the end of the timeline then deleting it) but what is the easy answer?
    thanks
    Cade Muhlig replied 19 years, 1 month ago 2 Members · 2 Replies
  • Shane Ross
    July 24, 2007 at 7:47 pm
    Press the DELETE key on the main keyboard…the one next to the + key and above the RETURN key. That DELETE performs a LIFT…leaving a hole. The DEL key above the arrow keys does an CUT…meaning that it closes the gap.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Cade Muhlig
    July 24, 2007 at 7:53 pm
    aha! i knew it was simple like that.
    (thank you lord for the cow)
    and thanks shane
