Activity › Forums › Apple Final Cut Pro Legacy › Preset Sequence Settings
  • Preset Sequence Settings
    Posted by Scott Gray on October 30, 2006 at 8:55 pm
    I have shot on an HVX200 in HD at 720p. The imported file specs for my clips show 960×720 frame size. I have my sequence setting set to the following:
    Frame Size: 960×720 HD (960×720) (16:9)
    Pixel Aspect Ration: HD (960×720)
    Why does the image not fill the entire frame when viewing in this sequence?
    Also, why does 720p footage always import as 29.97?
    Shane Ross replied 19 years, 11 months ago 2 Members · 1 Reply
  • Shane Ross
    October 30, 2006 at 9:45 pm
    [Scott Gray] “Why does the image not fill the entire frame when viewing in this sequence?”
    In the % window above the VIEWER and CANVAS select FIT TO WINDOW. Or you may need to adjust the windows to allow the footage to fill it 16:9. Going to the WINDOW menu and choosing one of the standard settings will make the footage fit perfectly…like TWO UP or STANDARD.
    Shane
    Littlefrog Post
    http://www.lfhd.net
