Activity › Forums › Adobe Audition › preset directory
preset directory
Posted by Hunter Christy on September 9, 2007 at 10:11 pmwhere are effects presets saved on your machine?
i am switching computers, and really need some ftt filter presets to take with me, but i can’t find them.
any thoughts?
THE BiG HONKIN’
“The Defenders Of Stan”-lots of after effectsEmmett Andrews replied 19 years ago 3 Members · 9 Replies -
Willie Toth
September 9, 2007 at 10:48 pmFor Pre Pro go to C > PROGRAM FILES > ADOBE > PRE PRO > PLUG-INS > en-US > VST FLITERS
For Audition C > PROGRAM FILES > ADOBE > AUDITION > VST FLITERS
Willie Toth
September 9, 2007 at 10:49 pmFor Pre Pro go to C > PROGRAM FILES > ADOBE > PRE PRO > PLUG-INS > en-US > VST FLITERS
Hunter Christy
September 10, 2007 at 12:06 amok. as weird as this sounds. i don’t actually have that. i cannot find it
THE BiG HONKIN’
“The Defenders Of Stan”-lots of after effects -
Willie Toth
September 10, 2007 at 10:20 amNow I am at a loss, OK try this open up on the edit side and go to EFFECTS and left click on ADD and REMOVE VST DIRECTORY … This should give you the location of your VST filters … I guess for me right now the bigger mystery is why don’t you have those folders, they are part of the program unless someone has purposely deleted them … Here is a sure fire way to find them if you can’t find them as suggested … Go the start menu and then search files and folders and do a search for *.fft ………….. WILLIE
Hunter Christy
September 10, 2007 at 5:43 pmok. doing a search for *.fft produced all the noise reduction samples and stuff, but i can’t seem to locate the filter process effects. those are the ones i really need.
see thats the other problem. my stupid audition, every time i go into edit mode, has a runtime error and closes.
i never had these problems with cool edit pro.
THE BiG HONKIN’
Willie Toth
September 10, 2007 at 6:28 pmNow we may be getting to the heart of your problem … What version are you using? Have you tried to uninstall and reinstall? I feel missing files is your problem and the reason you couldn’t locate the folders I told you to find … I would completely wipe the program and start from scratch …………… WILLIE
Hunter Christy
September 10, 2007 at 7:24 pmi am using cs2. i have done a a repair install, and an uninstall, reinstall.
it was really weird. it was working, then it suddenly stopped. out of nowhere. it says “Runtime Error! r6025-pure virtual function call”
i did a system restore…nothing. i just dont understand.
i am freaking out because i REALLY need one of the presests from the FFT filter (process) effect.
THE BiG HONKIN’
Willie Toth
September 10, 2007 at 9:00 pmDo you have a copy of 1.5 … 2.0 just sucks big rocks and I refuse to use it … Mystery problems seem to follow 2.0, I know this doesn’t help but you are not alone in this area … What presets are you looking for, maybe I can help … WILLIE
Emmett Andrews
September 10, 2007 at 9:21 pmAudition presets are stored in the Audition.ini file. Make a copy of that file and drag and drop it on the Audition.exe file on the second machine. Your presers should be moved.
Emmett
