Activity › Forums › Apple Final Cut Pro Legacy › Preset Add-Transition Speed
Posted by Ernie Santella on December 1, 2005 at 6:14 pmQuick question, when you CNTL-Click to “Add Transition cross-dissolve”, it always comes in at 30 frames. How can you change that rate to something different?
Annaël Beauchemin replied 20 years, 10 months ago 4 Members · 8 Replies -
Frank Nolan
December 1, 2005 at 6:46 pmGo into your effects tab in the browser, select the duration of the dissolve and change it to whatever length you want.
Ernie Santella
December 1, 2005 at 7:16 pmNo good. Yes, you can change the preset time in the EFX length window, and when you drag a dissolve into the transition, it takes that time, that’s great.
But, when you Cntl-Click ‘Add Transistion’ it’s always inserts a 30 frame diz. That’s the rate I want to change.
Nick Ryan
December 1, 2005 at 7:24 pmWell… I don’t know all the most efficient ways to do things, but for one:
Modify an existing dissolve, drag THAT dissolve to your browser (your project tab, not your effects tab), right-click it in the browser (or cntrl-click if only a 1-button mouse), choose “set as default transition”. Walah! Hope that helps.
Nick
Frank Nolan
December 1, 2005 at 7:35 pmIt will add the 30fr dissolve because that is what you have set as the default transition length. As I said change the default duration in the browser and the next time you control click on an edit and add transition it will add the new length transition you have set in the browser.
Ernie Santella
December 1, 2005 at 7:44 pmI must be doing something wrong. OK, Browser, Effects Tab, Dissove Bin, I changed ALL the dissolves (Additive, Cross, etc) to :20.
But, when you Cntl-Click Add Transistion – Cross Dissolve, It puts in a :30.
This is insane!
Frank Nolan
December 1, 2005 at 7:54 pmWhat version of FCP are you on? I am on 5.0.3 and I just did exactly what you described and it changes it to the new 20fr duration when I control click add transition. I even left the audio at 30fr and just changed the default video dissolve duration and with clips linked, it placed a 20 fr on the video and a 30 fr dissolve on the audio. May be it could be a version thing or?
Ernie Santella
December 1, 2005 at 7:59 pmI’m current 5.0.3 on a G5 DP 2.7. Nick’s suggestion above does work. So, Chalk that up as a ‘bug’.
Annaël Beauchemin
December 1, 2005 at 9:50 pmAfter you cahnge the transition lenght in the Effects window, try to right-click it (in the Effects window) and select “set as default transition”.
If it still doesn’t work, maybe you could try to trash FCP’s prefs…
