Activity Forums Adobe InDesign Preserving transparency from copy/paste of photoshop layers
  • Preserving transparency from copy/paste of photoshop layers
    Posted by Nathan Quattrini on April 8, 2009 at 6:29 pm
    I am trying to put some graphics from a PS file (via copy and paste of layers) into an indesign file. When I do, anything that should be transparent is white. I need to keep the transparency how it is in PS, so how do I get it to paste in properly?
    Matt Sepeta replied 17 years, 5 months ago 2 Members · 1 Reply
  • Matt Sepeta
    April 8, 2009 at 8:19 pm
    Nathan – You are going about doing it wrong…
    Open up your photoshop document that you want to put into indesign. Save it as a tiff with layers, highest quality possible. Note the location of the file and then go in indesign, hit command D (place) and drag out a field for it to rest. That preserves any transparency, and then if you want to edit the original photoshop document, right click on it from indesign, hit “Edit original” and it will pop right up in photoshop. Then save, and it updates indesign automatically.
    Hope this helps
    Good Day
