Activity › Forums › Avid Media Composer › Preserve VBI setting
  • Preserve VBI setting
    Posted by John Pale on December 28, 2009 at 6:55 pm
    Looks like we need to make a 2 second fix into a master already closed captioned (SD Digibeta).
    Has anyone successfully done this using the Preserve VBI setting in the Video Output tool (Avid Symphony DX v3.9)? I searched the forum, but the only post I found was an unanswered one from someone who could not get it to work.
    Bouke Vahl replied 16 years, 9 months ago 2 Members · 1 Reply
  • Bouke Vahl
    December 29, 2009 at 9:28 am
    Why not ingest a bit, insert on another tape and test?
    (Make sure you got a larger bit, as the CC info can be on tape way before it’s on screen.)
    If you got a client monitor that can do H/V delay, that might help.
    (you should be able to see if there is something there)
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pro’s
