Activity Forums Adobe After Effects Preserve resolution when nested
  • Preserve resolution when nested
    Posted by Jim Bachalo on October 12, 2013 at 1:42 pm
    Can anyone give a good example of when you might want to leave ‘Preserve resolution when nested’ switched ‘on’ in a composition?
    Local is the new global
    John Cuevas replied 12 years, 10 months ago 2 Members · 1 Reply
  • John Cuevas
    October 12, 2013 at 4:02 pm
    In the Advanced tab of the Composition Settings dialog box (Composition > Composition Settings), choose Preserve Resolution When Nested or Preserve Frame Rate When Nested Or In Render Queue for a composition to retain its own resolution or frame rate, and not inherit those settings from the containing composition. For example, if you deliberately used a low frame rate in a composition to create a jerky, hand-animated result, you should preserve the frame rate for that composition when it is nested. Similarly, the results of rotoscoping may look wrong when converted to a different frame rate or resolution. Use this setting instead of the Posterize Time effect, which is less efficient.
    After Effects /
    Precomposing, nesting, and pre-rendering
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
