Activity Forums Adobe After Effects preserve quality in a new composition
  • preserve quality in a new composition
    Posted by Mats Andresen on January 9, 2008 at 1:38 pm
    Howdy Cow!
    I have scaled some footage in a composition, and I need to move this composition into a new composition and scale it back to the original size.
    Will I then lose quality, or will AE understand that this is the same file (as it would with vector graphics) ?
    Thanks in advance!
    Sincerely
    Mats
    Peter Van der zee replied 18 years, 7 months ago 2 Members · 3 Replies
  • Peter Van der zee
    January 9, 2008 at 2:38 pm
    with the collapse transformation switched on, your footage will render original quality.
    (the little sun-like thing)
    vanderzee.tv
  • Mats Andresen
    January 9, 2008 at 3:40 pm
    I tried but then the new comp shows the same format as the original comp even if I have changed the scale to 100% x 133% in the new comp.
    I want to keep the aspect ratio as it is, I just dont want to loose quality..
  • Peter Van der zee
    January 9, 2008 at 3:56 pm
    Don’t understand, scaling doesn’t work with collapsed transformation on?
    1.Are you working with 3d swiched on? If so 3d should be on in the pre-comp too.
    2.Aspect-ratio can also be changed in the interpret footage dialog
    vanderzee.tv
