Activity › Forums › Adobe After Effects › Preserve layer size on pre-compose?
  • Preserve layer size on pre-compose?
    Posted by Scott Kimberly on August 31, 2018 at 12:04 pm
    Ive seen this posted several times, but nothing really recently.
    Im running AE CS5. I am watching a youtube tutorial from 2017 and at one point the author grabs a layer that is 200px wide and pre-composes it and moves all the attributes. His new pre-compose layer is 200px wide.
    Whenever I try to do the same, my pre-compose layer becomes the size of the entire composition (1920×1080).
    Is there still no way of keeping the layer size during a pre-compose? Am I missing a setting or something?
    Scott Kimberly replied 8 years ago 2 Members · 2 Replies
  • Walter Soyka
    August 31, 2018 at 5:30 pm
    I’d be curious to see the tutorial you reference, because what you’re describing shouldn’t be happening.
    “Leave all attributes” should preserve the layer size. “Move all attributes” will make a precomp that’s the same size as the containing comp, though you could resize/reposition this after the fact.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Scott Kimberly
    September 1, 2018 at 12:34 pm
    Walter, thank you for your reply!
    This is the tutorial I’m watching: https://www.youtube.com/watch?v=GLwpCNil3XE
    At around 10:50, he pre-composes the layer and moves all attributes. This behaves the way you are saying (doesnt change the size).
    However, right after that he clicks the “Collapse transformation” star on that layer, and THAT is what resizes his layer. I tried doing the same on mine, but it didnt seem to do anything so maybe I’m not using that part correctly.
