Activity Forums Maxon Cinema 4D Preparing object to be correctly exported using External compositing tag
  • Preparing object to be correctly exported using External compositing tag
    Posted by Tim Simmons on March 27, 2017 at 11:48 am
    I am having a hard time correctly preparing an object to be tracked in After Effects using Cineware and External Compositing tag.
    For some reason, the axes seem to be wrong. The green solis is moving from above, instead of from the camera. Also it rotates around the wrong axis. I went to Enable axis tool, and set the axis orientation of the phone to match the axes in the lover left corner of the perspective view. It didn’t work. I also played with Mesh->Axis Center->Axis Center dialog, but to be honest, I didn’t really get it.
    This is the file that is causing problems. https://www.dropbox.com/s/r8onj6nw6kngtbg/anima_1.c4d?dl=0 Anyone willing to take a peak at the source project and help me with the problem?
    Tim Simmons replied 9 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
