Activity Forums Apple Final Cut Pro Legacy Preparing for a large file
  • Preparing for a large file
    Posted by Mark Hammett on July 31, 2009 at 7:10 pm
    Someone is about to give me a large file to work with. It’s a Quicktime file and it’s only three minutes long, but it’s 10gig so I’m guessing it’s HD. This is not something I’m used to. I usually just play around with 4:3 SD footage.
    I imagine I’ll have to set the sequence differently? Will I be able to tell from the file how to set things up? I’m thinking about the frame size and aspect ratio options in the sequence settings.
    Any advice much appreciated.
    Mark Suszko replied 17 years, 1 month ago 3 Members · 2 Replies
  • David Battistella
    August 1, 2009 at 3:23 am
    Drop the file into a new sequence and let final Cut do the sequence presets for you.
    David
    Peace
    Check out my new web series.
    https://www.ripperhockey.com
  • Mark Suszko
    August 2, 2009 at 4:31 am
    Are you planning to make an SD product or an HD master?
