Activity Forums Adobe Premiere Pro Preparing 1440x1080i HDV for conversion to 1080p / 24p
  • Preparing 1440x1080i HDV for conversion to 1080p / 24p
    Posted by Rune Jacobsen on November 10, 2014 at 3:52 pm
    Hi all,
    I have a bunch of event video (wedding) in 1080i HDV 30fps format (which means 1440, but I also want to widen it to 1920).
    I am going to clean it up quite a bit using Neat Video.
    I want to go for a “film look”, which in my case means 24p and quite a bit of color grading (SpeedGrade).
    Should I do the 24p conversion as soon as possible? Is there a good description of this workflow available?
    I am on Windows and I have a Creative Cloud subscription. I was thinking of using DNxHD while editing in PP CC14 and some mild After Effects work, plus the SpeedGrade work.
    Does any of this look like a really bad idea?
    Rune Jacobsen
    Rune Jacobsen replied 11 years, 10 months ago 3 Members · 6 Replies
  • Tero Ahlfors
    November 10, 2014 at 9:57 pm
    [Rune Jacobsen] “(which means 1440, but I also want to widen it to 1920)”
    HDV is actually 1920 wide. It’s just anamorphic HD.
    [Rune Jacobsen] “I want to go for a “film look”, which in my case means 24p”
    Interpret the footage to run at 24fps after you’ve imported and edit in a 24fps sequence.
  • Rune Jacobsen
    November 11, 2014 at 12:24 pm
    Hi Tero,
    Thanks for your reply!
    [Tero Ahlfors] “HDV is actually 1920 wide. It’s just anamorphic HD.”
    I have a basic understanding of what anamorphic means, but in PP the video source clip shows as 1440×1080. I will have to actually do something to cause it to become 1920, right?
    [Tero Ahlfors] “Interpret the footage to run at 24fps after you’ve imported and edit in a 24fps sequence.”
    I will try your interpretation tip. But will this actually cause ever so slightly slower video? I.e. each second of 30fps video will become 24, then the 6 remaining frames will be “pushed” to the next second along with the first 18 frames? Or will it simply drop 6 of the frames each second to become 24fps?
    Still learning, thanks for any further tips!
    Rune Jacobsen
  • Tero Ahlfors
    November 11, 2014 at 12:55 pm
    [Rune Jacobsen] ” I will have to actually do something to cause it to become 1920, right?”
    Drag the video to the new item button and it should create a timeline with the proper settings. Or you can make a custom 1440×1080 sequence and choose the HD anamorphic pixel aspect ratio.
    [Rune Jacobsen] “But will this actually cause ever so slightly slower video?”
    It will change the lenght of the clip because it’s running slower. Basically it just runs the video at the new framerate showing every frame. It’s not dropping or adding frames. If you have a 24 fps sequence and you cut 30 fps footage in it then it will drop frames, but it will run the original lenght.
  • Jeff Pulera
    November 13, 2014 at 9:20 pm
    Hi Rune,
    You are correct that an HD video clip is 1440 pixels wide. Just drop that clip into a 1920×1080 sequence and Premiere will handle it just fine, and you can export as 1920×1080 later.
    Not sure about the 24 conversion, have not tried it myself
    Jeff Pulera
    Safe Harbor Computers
  • Rune Jacobsen
    November 14, 2014 at 8:20 pm
    Tero,
    Thank you very much for your help! Going into experimentation mode now. 🙂
    Rune Jacobsen
  • Rune Jacobsen
    November 14, 2014 at 8:22 pm
    Jeff,
    Thank you very much for your input. I’ll familiarize myself with this a little more to make sure I get it right. 🙂
    Rune Jacobsen
