Activity Forums VEGAS Pro Prepare DVD
  • Prepare DVD
    Posted by Knotts04 on June 12, 2007 at 2:51 am
    When I go to prepare my DVD a window comes upo and says “The slected folder is not valid. It is either not possible to create the folder or you do not have write access.” Wgat can I do to fix this?
    Laszlo Kovacs replied 19 years, 3 months ago 2 Members · 1 Reply
  • Laszlo Kovacs
    June 12, 2007 at 3:30 am
    are you using the defaults?
    The default prepare folders name (c:documentsandsettings\…etc…)
    may be too long or can contain charachters that DVDA does not support – I mean on localised versions of windows.
    I had similar problem, and setting up a prepare folder solved this issue. I named it like “c:\mastering”
    Hope I could help.
    By(t)e
    K.L.
