Activity Forums Adobe Premiere Pro PremierePro2 Limits Multicam edits per project?
  • PremierePro2 Limits Multicam edits per project?
    Posted by Thomas Macoy on March 15, 2007 at 3:25 pm
    I have a series of short video segments to cut together, and since they were all shot 3 camera (miniDV) I decided to try PPro2’s multicam feature. The first segment worked perfectly. When I synched up and enabled multicam on segment 2 though, I got no audio playback in the multicam monitor. Video rendered fine, and I can hear the audio if I scrub, but it will not playback at all in real time. After a couple restarts, I tried copying the relevant project files into a new project, set up multicam in there, and it worked perfectly again. Back to the original project, I tried closing Segment 1’s timelines and disabling multicam on it, but Segment 2 still refused to playback the audio. (And only in the multicam window; realtime audio playback on both the normal timelines is fine.) So while I do have a workaround, I’m wondering if anyone else has seen this; does PPro2, by intention or glitch, limit you to one multicam track per project? Or am I missing something else? Thanks anyone.
    Thomas Macoy replied 19 years, 5 months ago 3 Members · 4 Replies
  • Ashley M. kirchner
    March 15, 2007 at 4:02 pm
    I’ve edited several projects containing several multicam timelines and edits without any trouble. If I had to take a guess, I’d say it’s a glitch with your setup.
  • Thomas Macoy
    March 15, 2007 at 5:07 pm
    Should’ve posted that too. The rig is:
    Gigabyte MB (nForce4 SLI)
    Athlon X2 3800+
    2 Gigs RAM
    eVGA 7800GT nVidia video card
    WD Raptor 35 gig System drive
    WD regular (7200rpm) Project Files drive
    Windows XP SP2, fully updated
    I think all my drivers are up to date, but I’ll check. I believe I tried Accelerated GPU effects both on and off and got the same result.
  • Phocas Kroon
    March 15, 2007 at 10:18 pm
    Yesterday I did also a test for the first time with multicam. Also no audio in the multicam timeline.
    Then I found out that only soundtrack 1 is used in the multicam timeline.
    In the original timeline, soundtrack 1 was switched off, because I will use only the sound of track 3 and 4.
    Now I will try to copy/past track 3 and 4 to the multicam timeline.
    Maybe something like that is your problem too.
    Good luck
    Phocas Kroon
  • Thomas Macoy
    March 16, 2007 at 12:42 am
    That was one thing I checked actually- I know there’s a setting when you can pick if the audio gets cut along with the video, or if it uses only track 1 to output. (The Audio Follows Video option, under the Multicam Window options triangle; if I read you right, checking that on should let your edit read your audio tracks 3 and 4 without have to cut and copy them back into the final multicam track.)
    I know it’s not that setting in my case cause I still get audio when I scrub in the multicam window, which I think would imply some kind of performance issue, but I can’t say for sure. Thanks though.
