Activity Forums Adobe Premiere Pro PremierePro CC UI super sluggish hit?
  • PremierePro CC UI super sluggish hit?
    Posted by Francois Driessen on April 9, 2014 at 1:51 pm
    Hi there, guys.
    Hope someone can help with this one.
    My UI has become super slow on my MacPro3.1 8core 2.8 GHz, GTX680 CUDA, Quadro4000 UI. Os 10.8.5, 32GigRAM with PP (CC latest update). BMD DeckLInk SDI
    Media is read snappy from the RAID. (630 MB/s) and theres plenty of RAM. But its like PP stalls for a second or two every time I switch tools, Activate a drop down menu or try to select something. This is VERY annoying and I can’t work like this at all.
    I’ve tried trashing Prefs with no success. Any advice?
    Francois
    FireTrigger Inc.
    https://firetrigger.com
    Francois Driessen replied 12 years, 4 months ago 3 Members · 3 Replies
  • Justin Kavoussi
    April 9, 2014 at 4:08 pm
    Not sure if this is what’s causing it for you, but I’ve been having the same problem when I’m working on a sequence full of merged clips. Ended up having to remake them all as single-angle multicams and then had to go through replacing them in my sequence. I’d try deleting any merged clips out of your sequence as an experiment and see if that helps.
    Also, I’ve had some success with cleaning the media cache database. and sometimes, as a last resort, just deleting the media cache files & media cache database in the finder (though then premiere has to recreate all the pek & ims files which can take a while).
    Justin
  • Paul Neumann
    April 10, 2014 at 11:58 pm
    If you have your scopes open try closing them. They can be buggy to the overall operation at times.
  • Francois Driessen
    April 11, 2014 at 2:28 am
    Thanks. Good to know. But no scopes open…
    Any other ideas out there?
    Francois
    FireTrigger Inc.
