Activity › Forums › Adobe Premiere Pro › PremierePro CC – all preview files lost after Project Management
  • PremierePro CC – all preview files lost after Project Management
    Posted by Joe Barta iv on January 10, 2014 at 2:17 pm
    We upgraded from PPCS6 to CC a week ago. We finish a project. Render all preview files for the entire sequence, export using previews, and then use Project Manager to make a backup. When Project Manager is finished PP CC breaks all links with the preview files and we can’t re-link them. The original project has no preview files. The Project Managed project has no preview files. The last Auto Saved project has no preview files. Is this the way it is supposed to work?
    Bars & Tone
    SALUTE!
    Joe Barta iv replied 12 years, 8 months ago 3 Members · 5 Replies
  • Morten
    January 10, 2014 at 5:25 pm
    Preview files are kept in specific folders for each version of Premiere. On Mac this is in: /Documents/Adobe/Premiere Pro/.
    You could consider trying to copy from the 6.0 to the 7.0 folder, but the preview file format might have changed…
    – No Parking Production –
    Adobe CC, 3 x MacPro, 3 x MbP, Ethernet File Server w. Areca ThunderRaid 8…. and FCPX on trial
  • Andy Edwards
    January 10, 2014 at 5:44 pm
    Did you check include preview files when you project managed your final rendered sequence? It should grab the previews you created and put them in your final project managed folder. Just did a quick test and the preview files show up in the project managed version and in the newly created sequence (render is all green)
    Andy Edwards
  • Joe Barta iv
    January 10, 2014 at 7:43 pm
    Thanks for the replies.
    We usually select “Create New Trimmed Project” in Project Manager, that doesn’t give the option of “Include Preview Files”.
    It still doesn’t explain why PP CC would unlink the preview files from the original project.
    Bars & Tone
    SALUTE!
  • Morten
    January 12, 2014 at 2:04 pm
    If the original preview files were generated in CS6, then CC will assume a different file location.
  • Joe Barta iv
    January 13, 2014 at 3:02 pm
    Thanks Morten,
    When we converted the projects from CS6 to CC we re-rendered all the previews. Everything was green. We made an export of the main timeline using the previews. All good. We then used Project Manager to archive the project. After project manager finished everything systemically unrendered. You could watch it go clip by clip changing the status from green to red.
