Activity › Forums › Adobe Premiere Pro › Premiere Won’t Play Anything in the Timeline
  • Jon Barrie
    September 27, 2010 at 1:08 am
    This is an old post.
    Have you tried to search for similar problems you are experiencing? Someone else out there with CS4 has most likely had this problem and found a solution. CS4 has been around for a long time now.
    If you can’t find a solution, then start a new post with the details of your problem, version of the software you are using and specs of your system.
    Cheers,
    Jon Barrie 🙂
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Andy Hawk
    October 30, 2010 at 10:36 am
    As for video stuck on one frame while audio continues playing. Sounds like you are trying to deal with an old avi codec that CS4 doesn’t recognise.
    I had this before when someone handed me some footage to edit. They had exported as .avi but from a camera that was an ancient relic !
    Turns out I needed the mjpg decompressor. You may need a different one depending on what camera the footage came from. I discovered which one I needed by dropping the problem clip into AE project panel then tried to play it directly in the project panel (don’t play it from a composition as it will play fine in comp windows). When playing in project panel it came up with :
    “can’t find vids:mjpg decompressor”
    here’s a link to the mjpg decompressor if you need it
    https://smart.pannoninteraktiv.hu/video/codec/mcjpg30.zip
    after installing (by following readme notes in the zip)close Prem cs4 then reopen the project so it can recognise the missing Codec….Voila ! fixed.
    http://WWW.FootageNest.com
  • Thomas Brecheisen
    March 7, 2013 at 2:50 am
    This worked for me:
    Remove the Aggregate Devices plist file.
    1.Open the Finder and navigate to /YOUR_HD/Library/Preferences.
    2.Rename the com.apple.audio.AggregateDevices.plist file, or move it to the trash.
    3. Restart Soundbooth or Adobe Premiere Pro and retry.
    I didn’t even have to restart, but if you have the same issue I did (which sounds like you did) hopefully this will work.
  • Rick Sebeck
    February 20, 2015 at 2:52 pm
    For others searching for a solution…
    I was having the same problem. Timeline stopped playing. Viewer still acted normal, other sequences played fine. just one sequence would not play. All of my clips were multicam – one stereo track of audio in their preferences. One track soloed in the sequence view of the clips One of the clips in the sequence I opened in sequence view and enabled another track (I wanted to hear that mic for that moment).
    The issue didn’t start at first. But I have tracked it back to that. If I mute the track I enabled in the subclip the sequence the clip is used in will play again. Must be some audio down mix bug.
    Editor
  • Glenn Delaney
    December 11, 2015 at 3:06 am
    Had this problem earlier today. I’m editing with content off a hard drive. I closed down my anti-virus software and the timeline plays with no issue now.
    May have just lucked out, but as soon as I did this I noticed the problem was rectified.
    I use 360 Total Security, which at times can be a little invasive with some tasks. Hope this helps.
  • Kelso Nygaard
    June 8, 2016 at 1:52 pm
    Hey man 🙂 try to give premiere more ram. by going to: edit\prefrences and give it more!
Page 2 of 2
