Activity Forums Adobe Premiere Pro Premiere Won’t Export! Time Crunch
  • Premiere Won’t Export! Time Crunch
    Posted by Eli Portell on December 21, 2009 at 8:23 am
    I am in a crunch for time on a video I need to get done. Any help will be appreciated.
    Problem One) When i choose to export my video sequence from premiere it sets ou the export settings and once i am finished and press okay the media encoder does not come up.
    Problem Two) I have tried opening the program file for media encoder and when i try it says that processcoordinationclient.dll is missing from my computer. I have checked and found this file is under the media encoder folder.
    Is there any way i can get premiere to follow up on the export or get media encoder to recognize the “missing file” is not missing?
    Thank you for you help
    Eli Portell
    Jon Barrie replied 16 years, 8 months ago 2 Members · 1 Reply
  • Jon Barrie
    December 21, 2009 at 9:33 am
    Reinstall premiere and media encoder. Then if you have time, run the updates.
    If you don’t gave the time hut you have after effects dynamic link the ppro seq into AE And export it this from there.
    – JB
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
