Activity Forums DaVinci Resolve Premiere to Davinci, clip cant be linked to the media file timecode extents do not match
  • Premiere to Davinci, clip cant be linked to the media file timecode extents do not match
    Posted by Elliot Pollaro on February 21, 2013 at 9:10 pm
    Hi, I have been having a issue where I am going from Premiere to Davinci via XML. When I import, my RED footage isn’t connected in the timeline and it says “clip cant be linked to the media file timecode extents do not match” I cant seem to get them to connect properly. I went in and just imported 2 RED clips into my premiere timeline with no speed changes etc. and then exported a xml and sent it to davinci with the same results. I have my timecode in davinci set to 29.97. I even turned on the assist option in locating the clips on import. I either need to find a way to reconnect the clips in davinci or figure out what im doing wrong. I went to Final Cut X and dropped in two of the clips I used in my premiere project with a cross dissolve and the XML imported fine. So its definitely something with Premiere Pros XML.
    Liam Ward replied 13 years, 5 months ago 4 Members · 3 Replies
  • Margus Voll
    February 23, 2013 at 7:51 am
    yes it is!
    have you looked in premieres media pool that you have tape name ?
    it should be the file name you have in the front but without extension.
    it depends on your workflow lets say you used proxy or for some reason and do not have
    reel names in media pool then it will also not work.
    Margus
    https://iconstudios.eu
    https://vimeo.com/iconstudioseu/videos
    DaVinci 9, OSX 10.7.4
    MacPro 5.1 2×2,93 24GB
    GTX 470 / Quadro 4000
    Multibridge 2 Pro
  • Jef Huey
    February 28, 2013 at 6:30 pm
    Try using Export AAF from Premiere. That is working much better for us.
    Jef
  • Liam Ward
    March 21, 2013 at 5:01 pm
    Are you enabling or disabling ‘export as legacy aaf’?
    Liam Ward
    Sinking Ship Entertainment
