Activity › Forums › Adobe Premiere Pro › Premiere to Audition round tripping-non destructive?
  • Premiere to Audition round tripping-non destructive?
    Posted by Jim Bachalo on August 28, 2011 at 12:35 pm
    Hi
    Starting to integrate Audition into my workflow. I was wondering if, similar to dynamic linking between Premiere and After Effects, round tripping to Audition is non destructive.
    That is, if you go back and forth several times, applying audio effects, are the original audio files left untouched and only modified on your final render?
    Local is the new global
    Jim Bachalo replied 15 years, 1 month ago 2 Members · 2 Replies
  • Chris Tompkins
    August 28, 2011 at 4:13 pm
    Yes.
    You can always go back and remove all effects.
    Chris Tompkins
    Video Atlanta LLC
  • Jim Bachalo
    August 28, 2011 at 4:17 pm
    Thanks Chris, yes I am aware of the history undo. Great feature. But what I was asking is a bit different.
    I assume Audition doesn’t render out audio when you go back to Premiere…only saves the current state and any effects applied…am I correct?
