Activity › Forums › Adobe Premiere Pro › Premiere to After Effects Dynamic Link?
Posted by Sean Tatalovich on February 25, 2009 at 11:39 pmI know you can go from After Effects to Premiere to Dynamic Link but can you go from Premiere to After Effects?
Basil Iskandrian replied 13 years, 11 months ago 6 Members · 9 Replies -
Chris Buttacoli
February 26, 2009 at 5:49 amSure. Check the Adobe website, they have some cool tutorials.
Sean Tatalovich
February 26, 2009 at 6:16 pmI did. But I only see going from AE to Premiere not other way around?
Chris Buttacoli
February 27, 2009 at 6:04 amI see, you want to open a Premiere Project in AE via dynamic link. I don’t think you can. That would be cool. You can import a PProj file, and export out as a PProj file, but the dynamic link is not active.
Alex Udell
February 27, 2009 at 1:52 pmHi…
Select Clips in the Premiere Timeline and COPY
Open AE
Create a Comp of the same resolution at your Premiere Project.
Paste.
This will place the clips form the Premiere timeline into the AE Comp will all timing Preserved offsets preserved (except HDV apparently, there’s a bug with GOP media).
You will likely need to trim the comp to the area where the clips land.
That comp can then be dynamically link imported into Premiere Pro and edited into a timeline.
That way if you need to edit the comp after the fact, you can right click it in the Premiere timeline to open it and change it.
This also means that you don’t have to render in AE, but rather control your renders from the Premiere timeline.
Hope this helps,
Alex Udell
Editing, Motion Graphics, and Visual FX
Younversity TV
http://www.youniversity.tv -
Michelle Gallina
February 27, 2009 at 5:12 pmCS4 allows Dynamic Link from Premiere Pro to After Effects and from After Effect to Premiere.
Basil Iskandrian
October 29, 2012 at 6:20 pmHi,
Not sure if this was covered. Is there a way to export a Premeir sequence into AE so that the Premier sequence edits are preserved as individual layers in AE. Further a Dynamic Link is established so if later edits are made in PREMIER those edits update in AE? -
Alex Udell
October 29, 2012 at 7:05 pmHello…
After Effects can import a PPro edited sequence and see it as layers.
Once you save it as and AE project, however, it’s independent of PPro Project…not dynamically linked.
The dynamic link is really the other way….
You can send clips or stacks of clips from a seq in PPro to AE and use them to create AE COMPS.
if this is done….
if you replace sources in AE….then the AE changes propagate to the PPro clip container pointing to the AE comp…
Alex Udell
Editing, Motion Graphics, and Visual FX -
Basil Iskandrian
October 29, 2012 at 7:27 pmHi Alex,
That is what I suspected and have been experiencing.
Is there a work around/cheat that would allow for such edits to be made?
Thank you.
