Activity › Forums › Adobe Premiere Pro › premiere & Red Files
  • premiere & Red Files
    Posted by Dinesh Poojari on July 10, 2013 at 4:13 pm
    hi
    I m using Premiere CS6 & Editing a film which shoot on RED EPIC, now my total footage is almost 8TB and my timeline is fully ready for DI, i want to delete un used R3D file from bin as well as from HDD, So i can only send 2 or three HDD for DI, how to do it pls do the need full.
    And if i delete it from HDD the other file in R3D constructive folder will work properly or not pls tell me what should i do.
    Will Foxall replied 13 years ago 5 Members · 4 Replies
  • Angelo Lorenzo
    July 10, 2013 at 5:07 pm
    Use the Project Manager feature with the “collect files and copy to new location” as it will handle RED files properly (At least CC does, I rarely use this feature so I’d assume it’s the same for the older CS6 as I don’t remember it being listed as an improved feature).
    Alternately, if you really want to delete old files instead of copying files https://edlspy.felixhuesken.de/ EDL Spy in trial mode will help you at least see what is being used in your edit so you can manually delete around it.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Tero Ahlfors
    July 10, 2013 at 5:59 pm
    CS6 does collect R3D files correctly through the project manager.
  • Trent Happel
    July 11, 2013 at 12:50 am
    Yep, Project Manager ‘Collect Files and Copy to New Location’ should work for your needs. FYI, if you use the ‘Create New Trimmed Project’ option in Project Manager, be aware that the RED files will not actually be trimmed (it will copy the entire duration of the file on disk. Project will continue to have correct trimmed edits, though).
  • Will Foxall
    September 2, 2013 at 2:40 pm
    From my experience I’ve found that Premiere only copies the R3D files to the consolidate location when using the ‘Collect Files and Copy to New Location’.
    When I tried ‘Create New Trimmed Project’ it just left the R3D files alone. It didn’t even copy them over, let alone attempt to trim them. This would be more acceptable if it informed you what had happened. The Red footage was online in the consolidated project but it didn’t include master clips nor did it inform me that it had any difficulty…
    Strange. Is this what others have experienced?
    I’ve only tried this on Premiere CC (7.0.1) on a Mac so far.
