Activity Forums Adobe Premiere Pro Premiere Pro – Working remotely with proxy files ONLY
  • Premiere Pro – Working remotely with proxy files ONLY
    Posted by Chris Yost on January 15, 2019 at 8:10 pm
    Hey guys,
    I am trying to do some remote work on a project for a friend. He sent me a project file and file structure with PROXY’s ONLY, and tascam audio… Is it possible to replace the footage in the sequence with proxies WITHOUT having the actual original footage?
    When I try to manually attach proxies to the offline footage in the project window, I get the error message “Proxy Media and Full Resolution media must have matching audio channels”.
    Thank you all!
    Joshua Jackson replied 7 years, 7 months ago 2 Members · 2 Replies
  • Chris Yost
    January 16, 2019 at 1:23 am
    Thanks for the reply, Dave!
    The proxies have already been created. I have a folder full of proxies that I am trying to connect to the project. I’m asking if it is possible to connect the existing files to the project, in place of the offline hi-res media.
    Is this possible?
  • Joshua Jackson
    January 17, 2019 at 4:21 pm
    I do this quite frequently. I typically do a “Link Footage…” on the clip and (as long as the filename is the same) do an automatic linking via “Filename” (not extension, since this typically changes) in the folder that contains the proxies.
