Activity Forums Adobe Premiere Pro Premiere Pro won’t play back my audio for some reason.
  • Premiere Pro won’t play back my audio for some reason.
    Posted by Ryan Elder on August 26, 2019 at 12:36 am
    I recorded audio and video for a project. Premiere Pro accepts the video fine, but will not play back the audio tracks once they are imported into the program.
    If I play the audio tracks outside of Premiere, using VLC media player, they play fine without any issues. It’s just once they are imported into Premiere, they will not play back, not in the project panel, or on the timeline.
    I recorded using the same device I always do in wav files, 24 bit/48khz. Does anyone know what the problem could be?
    Ryan Elder replied 7 years ago 2 Members · 4 Replies
  • Greg Janza
    August 26, 2019 at 3:29 pm
    What codec are the files?
    Have you attempted to re-encode the files in AME or Resolve?
    https://www.linkedin.com/in/tmprods
    tallmanproductions.net
  • Ryan Elder
    August 26, 2019 at 11:33 pm
    The files are wav 24bit/48 khz if that is what you mean?
  • Greg Janza
    August 26, 2019 at 11:57 pm
    I misread your original post. Have you attempted to open them in Audition and then export to Premiere?
  • Ryan Elder
    August 27, 2019 at 1:12 am
    Now I haven’t but I just tried it and it worked… Works fine now!
